Used toner case almost full, on ricoh aficio 450
  • m_donakov
    replied
    Originally posted by Jomama46
    Clean the contacts on the side of the xfer case. Common problem
    This Helps Thanks to all
  • Jomama46
    replied
  • TonerMunkeh
    replied
    SP2-960 switches the sensor off. Make sure you visit the machine regularly as the transfer waste will back up and wreck the dev if it gets overfilled.
  • m_donakov
    started a topic Used toner case almost full, on ricoh aficio 450
    I got message Used toner case almost full, on ricoh aficio 450, i alredy cleaned used toner that is behind transfer roller how can i clean thos message
