Ricoh 2022 hard drive failure
  • landspeeder
    • Feb 2010
    • 355
    So does anyone have the hard drive, Ricoh 2022, part number handy so I can order one.
    Also can I take a notebook drive and create a drive that will work in this copier? That would be a cheaper way to do things!
    Thanks!
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • Eric1968
    • 2458
    B095 5763 HD:Toshiba:MK4032GAX:ROHS
    • landspeeder
      • Feb 2010
      • 355
      that is a ricoh 3025 hard drive...what I need is a ricoh 2022 hard drive number....unless that one will work in it?
      • Eric1968
        • 2458
        There's an MB out for the HDD of the 2022/2027. The old part number has changed, so I guess it will work.
        • landspeeder
          • Feb 2010
          • 355
          sooooooooo does that mean the part number is the same as a 3025?
          • Eric1968
            • 2458
            Just searched the 3025 parts list and the HDD is the same as the 3025.
            • landspeeder
              • Feb 2010
              • 355
              please help me with your last post..are you saying the 2022 hard drive is the same as the 3025 hard drive
              • Eric1968
                • 2458
                Yes. I searched for a HDD for the 2022/2027 and the part number is the same as the 3025/3030.
                • landspeeder
                  • Feb 2010
                  • 355
                  awesome!!! thanks
                  • jonhiker
                    • 661
                    Thanks!
                    yes, you can use a notebook drive and it will work in that copier. you do not need to order the drive from ricoh.
                    • daveyball
                      • May 2009
                      • 314
                      Don't use the Ricoh part no, just buy from your local computer outlet, it's just a IDE laptop HDD, ricoh will charge you about 4 x the shop price
                      • landspeeder
                        • Feb 2010
                        • 355
                        thats so cool.......what can I say! what format do you use or does the copier do it and how?
                        • Herrmann
                          • Jan 2006
                          • 792
                          Take any notebook IDE Hd >20gb , insert it into the Mashine, go into Service Mode SP5-832 and select Format all, after that do SP 5853 (Stamp Data download) and you are done
                          If in need of Service mode press Yellow-->1-->0-->7 and hold Red until Service Mode appears
                          Good Luck
                          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                          • landspeeder
                            • Feb 2010
                            • 355
                            Herrmann...you make it sound so easy...and it is!!! We have a old Xerox phaser 8400 hard drive, Hiatachi 20g, laying around and it works! A cold "beer" or two for you!!
                            Much thanks to all !!!
                            • secretweapon23
                              • Jul 2010
                              • 69
                              To everyone who still don't know, you can replace the HDD of the machines using ordinary HDD(IDE or SATA)that can buy on any local computer outlet. Any size is acceptable just format the HDD on the SP mode after replacing.
                              Hope can help....
                              Anyone who has never made a mistake has never tried anything new.....A.E.
