This piece of **** is dropping toner on the copies...spots on copies and sitting in bottom of drum unit. This is after changing the dev., and re-building the drum unit. We did reinit the dev.....hmmmmm what ya think bucko?
Ricoh 2035 is dropping toner
You never realize how cheap a professional is until after you let an amateur do it....and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!! -
the mylar is new and we are leaning towards the toner density sensor causing over toning...what do you thinkYou never realize how cheap a professional is until after you let an amateur do it....and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!Comment
Have to go back on site tomorrow...so I will get the readings and let you know....
Thanks..have a great niteYou never realize how cheap a professional is until after you let an amateur do it....and
You also might want to do continuity check between drum shaft and frame. the drum ground in that frame are really flakeyComment
thanks for the idea...is a bad ground on that model quite common? If you find its not good what do you do to correct it...ie some type of modYou never realize how cheap a professional is until after you let an amateur do it....and
At one point they changed the rear drum bearing on the frame because it was losing connectivity between the inner and outer races. Later they added a ground strap over the bearing as a mod,sigpic
A+; Network +; PDI+Comment
have to have a look...back to you laterYou never realize how cheap a professional is until after you let an amateur do it....and
I have had this problem with 2035. I think its related when using generic toner - this machine can also have the toner becomes completely repleted.
I checked everything else but the problem kept on coming back. I had concluded that the toner was bad and needed replacing - however, cleaning of those toner blotches on the drum and transfer belt removed the mess and in the end stopped coming. Try with toner replacement even though I did not do that - its my hunch that the problem might be eradicated as the machine gains mileage.Comment
