key counter interface unit MP4000 - what signals are on particular pins ?
  • jackb
    [Misc] key counter interface unit MP4000 - what signals are on particular pins ?
    I had installed a key counter interface in my MP4000 machine. I want to use it to plug in an external controller (computer software via a I/O card). This card would be connected with a wire through a bd9 connector placed on a cover of the machine. To connect a key counter interface to my controller I need an info about what signals are on which pin in this key counter interface. I can't find such information in any documentation. Could anyone help me ? Thanks
  • Jomama46
    • 2900
    Are you talking about the 4 pin connector?
    sigpic
    A+; Network +; PDI+
    • jackb
      There is no 4-pin connector on the key counter interface module. There is one 13-pin connector on top, which is used to link it to a MP4000 mainboard, there is 6-pin connector on the left and another, 7-pin connector on the right (both in white cover) and one wide, 20-pin connector on the bottom (in black cover), which I intended to use for connecting with an external controller. I need to find three signals: ground, unblocking/unblocking the device and page counter.
      • Jomama46
        • 2900
        There is a 13 pin counter connector at cn214 on the IO board. Did you see that one on the P2P? E8 pg 2
        sigpic
        A+; Network +; PDI+
        • oldschool
          • Mar 2007
          • 245
          Normally when we vend this model an optional interface board is required (Type A EDP) that board has a 20 pin connector on it. On that connector Pins A-9 and B-9 bring the copier ready and A-10 and B-10 are the copy count lines.
          That model should have a 4 pin key-counter connector on it. The Ricoh keycounter uses pins 1 an 2 to bring the copier ready and 3 and 4 as the copy count lines.
          Jamex Tech Support: Saving the world one phone call at a time.
          • tcs04
            FORMER Techie
            • 1183
            As mentioned.... Optional Counter Interface Type A. EDP 413012
            Fitting instructions in service manual.
            • techsass
              • Dec 2010
              • 248
              I only have the Mp4001 manual & the Ricoh web is down, but it SHOULD be the same.
              Since it's a BW box, I wouldn't mess with the 20 pin setup. That's used mainly to differentiate between BW vs. color as well as prints vs. copies, etc.
              Hopefully there's a jumper on the connector. That will be the Go/NoGo pins and the other 2 will be the counter pulses. Assuming it's a 4 pin connector.
              Pages from Mp4001.pdf
              • jackb
                Thanks! I finally dismounted the interface module/board and connected to a 4 pin (red) connector on the mainboard.
                • janam4u
                  Re: key counter interface unit MP4000 - what signals are on particular pins ?
                  i have a ricoh aficio mp 2550 with the 4 pin connector mentions above and am trying to connect it to a reset-able remote count meter the on/off -enable for copy was easy to figure out but can some tell me more about the counter signal
                  • oldschool
                    • Mar 2007
                    • 245
                    The MP2550 doesn't take the optional board. So you have to use the 4 pin connector.
                    Pin 1 (ground), pin 2 (5VDC Counter set when low), pin 3 (24 VDC) and pin 4 (24VDC low counter). Each time pin 4 drops low (usually at each paper feed) You'll see 24VDC across pins 3 and 4 for about 100 milliseconds. That should drive the counter one click.
                    If you'd like a replacement for that old counter check out our True Count. It comes with all you need.
