mpc2800
  • RebelPhoenix
    • Oct 2008
    • 138
    #16
    Originally posted by Eric1968
    Yeah, sure!!! If you think you're so smart, why not post the whole conversion procedure right here?
    I don't think I am so smart. You are continue to go to sleep. I told just this is possible. But I don't know conversion procedure. This conversion procedure applied the machine in Turkey. Maybe You must come to Turkey and You want to learn it. Maybe you found a stupid person. And He say the conversion procedure to you. Topic starter is a Turks. He made a bad mistake. Because Europe is just sleep. Europe's technicians isn't a technician. You show a SC-322 on a AF-2045, after change the LD unit. But here is different We open the ld unit. And Clean the laser diode lenses.
    • RebelPhoenix
      • Oct 2008
      • 138
      #17
      Originally posted by Gift
      I think it's likely possible that the controllerboards/bcu are identical on the hardware side but that there is some kind of (not replacable) NV ram or different coded ID chip protecting the boards from beeing hacked within the service/factory SP level.
      If one is able to locate and read out/write these chips it might be possible to upgrade a machine without buying new PCBs.
      That's all assumption of course..
      This is true. I think They found this Id chip, They are disconnect this ID chip on pcb. After change the information on ID chip(Maybe a fram or eeprom)
      • RebelPhoenix
        • Oct 2008
        • 138
        #18
        We aren't deceitful. Manufacturer is deceitful. Because They by making some small changes. After They earn more money.
        MP1600 -> MP2000(Only change copy speed)
        AF-1060 -> AF-1075
        AF-2060 -> AF-2075
        MP5500 -> MP7500
        MPC2050AD -> MPC2550AD
        MP6001 -> MP7001 (Only)
        MPC2800 -> MPC3300
        MP9000 -> MP1350
        PRO906EX -> PRO1356EX
