Ricoh 1357ex jam code 069
  • angelntx
    • Aug 2009
    • 62
    [Jamming] Ricoh 1357ex jam code 069
    We have a Ricoh 1357ex that has been giving a jam code of 069. The company only runs two sided. trays 1,2 and 3 run fine. When the paper comes out of 4,5 & 6 is when the issues start. Duplex assembly and the CIS sensors have been replaced. Firmware has been upgraded. Pm's are up to date. The motors for the LCT in the vertical path have been swapped around. The motor in the vertical path for 1,2 & 3 has been replaced. Any suggestions?
    angelntx
  • shedman
    Code 69 'paper bank relay sensor - lag' Try swapping or replacing sensor.
    • katash
      • May 2010
      • 221
      did you do sp 1909 002 adjustments for the cis?
      • RICOH MFP
        • Apr 2011
        • 2
        Hi,angelntx
        My suggestion:If the machine counter is higher than 1,000K;replace the torque limiters.Because the torque limiter is damaged by the timing error will cause a paper jam 069 and the machine display show as B1.
