MPC 4000 Jam 19
  • bostjanma
    MPC 4000 Jam 19
    I have a lot of jam no.19 (fusing exit sensor ON) on MPC4000. Copier works normaly usualy in the morning we have 3-5 jams only no.19. I check fusing unit, ivertor and exit unit but it likes good. Do you have any problems with this jaming?
    THX
  • teebee1234
    • 1670
    Found this in the Global Knowledge Base......
    [Symptom]
    Fusing unit jam (Jam code 19: Fusing exit ON)
    The problem occurs under the following conditions:
    • It occurs with all trays (1 through 4, by-pass).
    • The leading edge of the paper stops after exiting approximately two centimeters from the fusing nip.
    • The paper does not reach the fusing exit sensor.
    • The image is not distorted.
    [Cause]
    Fusing/paper exit motor (AX060369) is faulty.
    [Resolution]
    Replace the fusing/paper exit motor (AX060369).
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • ricoh-man
        • May 2011
        • 10
        I see 3 possible problems:
        1. Fusing Exit Plate (but only at fullcolor and hightoner images)
        2. Fusing Exit Sensor oder harness
        3. Fusing/paper exit motor
