Mpc3500 immediate fax tx printout
  • mikadonovan
    • May 2008
    • 2937
    I have the machine set to print out a TX confirmation report for every fax (Fax parameters switch 03 bit 05) but it is not working. What could I be missing?
    NEVER ASSUME ANYTHING
  • teebee1234
    • Jul 2008
    • 1670
    If TX Status Report is set for one of the quick operation keys, it will override the parameter setting. If it is programmed and the key isn't highlighted, the report will never print out - only on an individual basis per job if the operator selects it. Is memory transmission set also (sw3 bit0)?
    • mikadonovan
      • May 2008
      • 2937
      That has to be it. It is set for one of the quick operation keys. Good call, TB. Thanks
      • Jomama46
        • 2900
        if the report is on auto, it will not print a report for immediate transmissions.
        sigpic
        A+; Network +; PDI+
        • mikadonovan
          • May 2008
          • 2937
          What exactly do you mean?
          • Jomama46
            • 2900
            Immediate transmission means it doesnt scan into memory first, Press On Hook dial, dial the #, wait for the chirping and press start.= no xmission report.
            sigpic
            A+; Network +; PDI+
            • mikadonovan
              • May 2008
              • 2937
              Got it.
              • iMind
                Vacuum Cleaning Expert
                • Mar 2008
                • 1116
                • Jomama46
                  • 2900
                  cats were once worshiped as gods in egypt, they have never forgotten it
                  sigpic
                  A+; Network +; PDI+
                  • iMind
                    • Mar 2008
                    • 1116
                    holly cow... hehehe
                    • teebee1234
                      • Jul 2008
                      • 1670
                      The only reason I thought of it is because I had the same issue a few months back. Hope that is the answer..
                      • mikadonovan
                        • May 2008
                        • 2937
                        He got run over by another tomcat. He loves to go out and fight at night, and sometimes he gets his old ass kicked.
                        • iMind
                          • Mar 2008
                          • 1116
                          LOL, now did you get the thing working with (sw3 set to bit0) like teebee said.
                          • mikadonovan
                            • May 2008
                            • 2937
                            Yea, I got it working. The bit switches were already set correctly. I just disabled the quick key function and everything was fine.
                            • iMind
                              • Mar 2008
                              • 1116
                              Thanks for the feed back
