multiple sheet feed thru document feeder on a 201 ricoh
This was addressed with the 161. They changed the spring that applies pressure to the sep roller. It lessened the pressure. I would try to reform it just a little to see if there is an improvement.
sigpic
A+; Network +; PDI+
