Ricoh 2045e
  • Donk54
    [Electrical] Ricoh 2045e
    Have a machine that appears to shut down and other times it puts up a SC690 code
  • Jomama46
    • 2900
    Don't know what "appears to shut down" means but 690 is a defective BICU.
    sigpic
    A+; Network +; PDI+
    • john_551
      • May 2009
      • 23
      I have the same exact problem at the moment.
      I have a 2045e that shuts down. When the main power is turned on the power led comes on for a fraction of a second then goes out.
      I've also had it come up with the SC 690 code as well.
      I've replaced the BCIU board, checked my connections. Now when I turn on the machine the main power led comes on, but my panel and lcd are dead.
      I've already replaced all the interlocks, 6 in total, as the machine was very dirty.
      Has anyone seen this before? I'm starting to run out of ideas, also checked all fuses on the PSU and they all test good.
      Any help would be greatly appreciated.
      • Jomama46
        • 2900
        Look at the SC history and see what other codes have been generated since the problem began but weren't displayed
        sigpic
        A+; Network +; PDI+
        • john_551
          • May 2009
          • 23
          I can't do that at the present time since I can not get the machine up to go into SP.
          • Jomama46
            • 2900
            As a test, replace the power supply unit
            sigpic
            A+; Network +; PDI+
            • john_551
              • May 2009
              • 23
              I do have a psu unit here. I am going to replace it next. I've been look at goose's guide, ricoh etc... This machine just seems to hate me. I'll let you know how I make out.
              • Jomama46
                • 2900
                Well, its old and grouchy.
                sigpic
                A+; Network +; PDI+
                • JustManuals
                  • Jan 2006
                  • 9838
                  This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
                  Just Manuals | The Internet's largest selection of manuals | Instant Downloads
                  Paul@justmanuals.com
                  • DiskCopy
                    • May 2011
                    • 33
                    I had this problem with LD Unit and Flat Cable broken.
                    • teebee1234
                      • 1670
                      Can you get it to boot up with the front door open? If so, then you could pull up the SC history.
                      • john_551
                        • May 2009
                        • 23
                        What a piece of crap.
                        I replaced the PSU unit, BCIU, IOB and controller box.
                        Same damn thing, turn on the main power, and the power LED flashes for a second and goes off.
                        All components replaced were checked and tested in a good working machine.
                        I had it unplugged for a few minutes and decided to try it again, it started up and started to load.
                        Looked like ti was ready to run and then just shutdown again.
                        I had this before all this, the machine would sometimes power up and boot you could even do a copy, but then it should just shutdown for no reason.
                        I will check the flat ribbon cable on another visit, I'm getting so sick and tired of this machine.
