Limitations and control of Ricoh machine
  • PinevskiS
    • Jul 2009
    • 283
    Hi.
    My question is.
    Is there any software that Ricoh can control the printing without user code some obvious limitations.
    We have a server that runs on Domain.
    Any software that can down from the ricoh-support.
    Thanks.
    B.R.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Re: Limitations and control of Ricoh machine
    Check this: Print Management, Print Count, Print Tracking, Print Control and Print Quota Software for Local and Network Printers.
    sigpicWe can all Win, but at the end we all loose. Save the greyhound
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      If this is for your own use, that's fine, but one big caution on suggesting something to a customer that you can't support: If something should go the least bit haywire, it all of a sudden becomes your fault.
      Nothing like being held responsible for something that you have no control over.
      • tonnerboy
        • May 2011
        • 212
        Take a look at this software PAPERCUT. However, if you want something reliable and supported by Ricoh I advise you Equitrac.
        Edit: Well, i did not read carefully. I supose you want samething free... and this is not free.
