Ricoh Aficio 2238c
  • Dean
    • Feb 2007
    • 19
    Ricoh Aficio 2238c
    I need to set up the scan on this model but I have not had time to play around wit the machine. I have set up scan on Sharps & Kyocera Mitas.
    I need any advice and drivers that anyone can provide.
    Dean
  • jeffreyozz
    • Mar 2007
    • 52
    which scanning are you doing? I am going to assume that you are setting up twain scanning so that the end user can scan to their pc. you need the twain driver (ricoh-usa.com/downloads) and either scanrouter or desktop binder, which if you have the drivers disk for the machine they should be on there. If you have a choice of software my preference is desktop binder. It gives you a handy task bar so scanning becomes really easy for the end user, plus you can designate where to store the scans. Probably not much help but a start.
    • Fearless V K
      • 620
      We usually set up the scanner to scan to a folder using SMB, or scan to email. There are no other software app's required to do it that way, also scanner destinations can be chosen directly from the machine, unlike twain where you would have to set your docs, go back to your pc to scan them, then go back to the machine to get your originals.
      Don't take that toner with me!
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        This unit will do SMB and email, It's all in the user doc's that come with the unit, Or get from the ricoh public site.
        Mystic Crystal Revelations
        • salgua6869
          THIS MACHINES HAVE SCANNING ENBEDDED IN THEM, MEANING USING THE MACHINE'S INTERFACE OR USER TOOLS CREATE A PATH SUCH AS //SERVER name or ip/folder name. make sure to set proper folder permissions and authentication on the server.
          by default the login to the machine's interface is blank user name and "password" for password, address book, add user and from there it should be self explanatory.
          • rthonpm
            • Aug 2007
            • 2854
            If you are looking to do SMB scanning to a Windows 2003 server you will need custom firmware for this machine to allow it to do packet signing. This is only available from Ricoh's tech site.
            • Jomama46
              • 2900
              Also TWAIN scanning wont support scanning as PDF
              sigpic
              A+; Network +; PDI+
              • Llama God
                • Mar 2009
                • 1353
                Packet signing is disabled by default on Win 2003 Server, however it is on by default on SBS 2003.
                Packet signing can be turned off on the server, subject to the end-user's IT guy's approval, by following these instructions:
                1. From Administrative Tools open Domain Controller Security Policy
                2. Select the Security Settings\Local Policies\Security options folder
                3. Double-click Microsoft Network Server: Digitally sign communications (always), then select Disabled and click OK
                4. Double-click Domain member: Digitally encrypt or signsecure channel data (always), then select Disabled and click OK
                5. Click start then run, type gpupdate into the box and press enter to force a group policy update.
                Alternatively, install Scanrouter or use scan to email via their exchange server, if they have one.
