MP2851/LD528
  • ucinn
    • Jun 2009
    • 383
    MP2851/LD528
    I'm getting an SC672 right out of the box..not even 1 copy on it. Won't let me into service mode. I have a machine for swapping but running out of stuff to swap. I swapped the controller, HDD, Ram, NVRAM, Whole op panel..... What's next on the list? I'm running out of ideas.
  • Herrmann
    • Jan 2006
    • 792
    Re: MP2851/LD528
    Check harness to the ID Sensor, it might look like this:
    If so, the PSU is damaged also, resulting in several errors, so FIRST check harness, then replace PSU
    In Addition, check FU6 on PSU
    Hope, that helps
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • Gary Bowen
      Bowdog
      • Mar 2008
      • 250
      Re: MP2851/LD528
      Out side of what you have listed, Goose's Guide twice mentioned reseating the MBU Board on the Fax Unit. But you said this happened right out of the box?
      • ucinn
        • Jun 2009
        • 383
        Re: MP2851/LD528
        Correct, and I have removed the fax unit from it to no avail.
        Hermann.. thanks, I will check that first thing in the AM.. I did check all the fuses on the power supply and they all check good.
        • ucinn
          • Jun 2009
          • 383
          Re: MP2851/LD528
          Checked it, that was all good...finally found it..ended up being the IPU board..hope this helps someone else.
