Hi, I have a savin 4045 with a sc329 error. code appears as the first copy is being made. have tried sp2109 but it does not adjust and actually throws the sc 329 upon executing. We have tried a different laser unit and BICU board that both work in another machine. Please advise. Thanks
sc 329 savin 4045
Re: sc 329 savin 4045
You did not say when this first started happening. Because you have already tried another Laser Housing, this should rule out a problem with movement of the LD Board, operation of the Laser Positioning Motor or a bad LD Board. I have seen a problem with the Flat Cable before (but am not sure what error happened). You did setup the new Laser Housing with SP2109? Here is a copy of the SP2109 setup.Attached Files -
Change the door switches above the fuser. They cause odd laser issues.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Tonernick
Fixed. Thanks for the beam pitch adjustment. Turns out we were skipping 1 step. Thanks againComment
