MPC 3001 Cannot add user through WIM
  • carlosp
    Anyone ever have trouble adding a user through the WIM? I get an unexpected error message. I have updated all software and verified the NIC is on.
  • teebee1234
    • 1670
    Re: MPC 3001 Cannot add user through WIM
    At what point do you get the error, when you initially try and open the WIM or when you try and add a user?
    • carlosp
      It happens at the point where I try to add it in the address book.
      • chaunce54
        • Sep 2009
        • 32
        I have seen this happen before. Make sure that the page is completely loaded before pressing the apply or ok button on the page. If that is not the case, maybe there is a setting problem in the browser that is preventing it from working.
        • WildbillC
          • Oct 2010
          • 49
          I agree with the last post, try Firefox.
          • salonpas
            when updating do not use the machine as it will show error also.
            • carlosp
              resolution: reseated all boards and chips on controller. Found that fax battery board was not seated fully, not sure this was the cause, reassembled and now connects.
