Hello all, I tried to look the code up, but it's not there. other models point to the controller or op panel. Any suggestions?
MPC6000 has error SC 672
Re: MPC6000 has error SC 672
There's a few firmware updates for this SC, might be a good place to start.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
trottinbob
672 is controller start up error. Start with basics. Try booting from firmware card and install "latest & greatest" if possible (see below) . If not working. Disconnect the Hard drive and try to reboot . If not working pull the fax board out and try again. Reseat memory dimm's try again . If still failing. Try booting without the Print/Scan sd card.
If this is older unit the firmware was a known fix . Had sleep issues (STR) when on network.
System 1.08 or newer along with Web Support 1.08 or newer and NCS 7.11 or newer.Attached FilesComment
