ricoh aficio 2090
hi , yesterday a af 2090 propped up a error msg sc 870 and sc 925 hard disk error in spite of clearing the memory the error still persisted so i decided to remove a set of harddisks from a good working machine to install on the m/c showing error the same error propped up.Now i put back the harddisks from i removed from the good working the m/c which was working well now shows the same error and sort,edit, duplex options are disabled i am in a fix can someone pls help i'm desparate.
thanks
thanks
