The machine only has copy with no harddrive and ricohsaid to replace the laser which I did and still have this code. Any suggestions would be great thank
savin 2522 SC 984
Re: savin 2522 SC 984
Check and re-seat all the wire harnesses on the SBCU PCB / if that does not work replace the SBCU PCB.- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - Brother - Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
984DPrint image data transfer error After a data transfer begins from the controller to the engine via the PCI bus, the transfer does not end within 15 s. Controller board defective
BICU defective
BICU, controller disconnected984DPrint image data transfer error After a data transfer begins from the controller to the engine via the PCI bus, the transfer does not end within 15 s. Controller (SIMAC) board defective
BICU defective
BICU controller disconnectedComment
