Savin 9240 Web Elimination
  • Supertech1
    • Jun 2010
    • 5
    [Misc] Savin 9240 Web Elimination
    I heard a while back that you could use an oil roller from one of the old
    savin/ricoh's in place of this stupid hard to replace web on the 9240. Can you please refresh my memory and tell me how to do this???
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Savin 9240 Web Elimination
    there is a thread that explained about this, I will try to search for it.
    Nobody is perfect..
    • Supertech1
      • Jun 2010
      • 5
      Thank you for looking at this. I knew I should have book marked this info. when I got it. It was actually a Ricoh rep. that told me about it. I will keep looking as well.
      • rsyarcia
        • 711
        yes I need the link also.
        Nobody is perfect..
        • teebee1234
          • Jul 2008
          • 1670
          Here you go. I guess the only caveat is to make sure any other techs who may work on a modded machine know to check it on a pm call since you won't get a low web indication.
          • rsyarcia
            • 711
            many tnx teebee
            Nobody is perfect..
            • pixiq8884
              The only problem I have seen out in the field is that if a flat spot develops on the oil roller, then the oil roller no longer rolls with the hot roller and hot roller develops rotational line and gets ruined quickly. Its quite a bit of work replacing the hot roller and they seem to last 600k+ with the web. So I think spending extra 15mins replacing the web is well worth the effort. After a couple of web replacement, its it NOT really difficult or THAT time consuming to replace the web anyway imho.
              • Iowatech
                Not a service manager
                • 3930
                For what it is worth, I think this might be the thread you were looking for:
                http://www.copytechnet.com/forums/ri...bulletins.html
                • jonezy999
                  just one copy??
                  • Feb 2010
                  • 952
                  Need to trim the springs more to prevent the roller from jamming.
                  Side note, I once ran an MP5000 without the web or oil roller for an entire PM cycle. Fuser looked fine after 300k.
                  I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
