Problem with ricoh SPC232sf on Scan to folder
  • Gesttech
    • Oct 2009
    • 123
    Hi
    I have a problem with ricoh spc232sf. My problem are scan to folder on window7.
    When i shared folder on win7 & check the path, its ok on win 7.
    I program the path in the web image monitor, when i check on ricoh spc232sf connection fail
    but on win xp,server 2003 its ok
    What wong on Window 7? Can someone tell me what to do.
    Thanks.................
  • sandmanmac
    • 3981
    Re: Problem with ricoh SPC232sf on Scan to folder
    Originally posted by Gesttech
    Hi
    I've never worked on one of these, but with the larger Ricohs, It's almost always an out-dated firmware issue
    • bullwhipit
      Hi
      Make sure that all your security and permissions are set on the folder
      I would add everyone and then go back to the MFP and see if you can browse to the folder
      • spaceman99
        • Jul 2009
        • 174
        You will need the lateset firware on the mch....Win7 Nightmare
        goodluck
