Ricoh SP C430N - Labels print out light
  • mfugate
    • Jul 2025
    Hello Folks,
    I have a Ricoh SP C430N printer and when printing Avery labels they are barely visible. Everything else prints out fine, even cardstock.
    I assume this is because of the finish on the label paper. Is there a way to resolve this. Tryed changing the settings under Menu, Maintenance, General, Lable Paper Settings for Bypass tray from 6 (default) through to 1 without any change.
    Any help out there??
    Thanks, Mark
  • rthonpm
    • Aug 2007
    • 2854
    Re: Ricoh SP C430N - Labels print out light
    First off, make sure that the labels are for a laser printer. I try to steer my customers towards the laser only labels as opposed to the laser/inkjet variety. The cost is a little more, but it makes for fewer calls and issues.
    Also, check to see if the coated paper settings make any traction in terms of better output.
