big trouble on my mp c2500
  • donny
    Hi there,
    I had serious trouble with my mp c2500. when i print using plain paper/special paper type in tray 1 there is no trouble about it. but if i try use it in tray 2 or bypass tray (with all kind of paper and all position - landscape/portrait), the sc 491 error code show up directly on display. I guess there is some trouble with the paper transfer roll (i have no info about the part's name). Does anyone know how to solve this problem? Thanks a lot
  • JustManuals
    • Jan 2006
    • 9838
    Re: big trouble on my mp c2500
    Paul@justmanuals.com
    • Eric1968
      • 2458
      It's a High Voltage error. Could be drum/developer voltage problem, or something is wrong with the transfer voltage.
      Check all connections. As a last resort, replace the High Voltage board.
      • donny
        But it getting troubled when i took in full colour mode. if i get in b/w there is no problem about it. could it be something wrong with one of colour dev? (c/m/y)
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          It's obviously gunna be one of the colour units. Is this the initial problem or was it created while doing other work?
          I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
          • donny
            even just one single work. at first it get well when delivered half of paper into first roll (try it in bypass tray). then the warming process up is on (no idea what name of the process is). then when it going to the next process, the error code is directly show up (sc 491). not the same way if i try it using b/w mode
            • TonerMunkeh
              Professional Moron
              • 3865
              Time to call in a technician methinks, sounds like this little beastie needs a bit of digging around.
              Hit it.
              • Herrmann
                • Jan 2006
                • 792
                This statement confuses me. Does it really do all things including color printing and so on out if tray 1 ?
                This would imply, that hvt, dev and drum units are all ok.
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                • jonezy999
                  just one copy??
                  • Feb 2010
                  • 952
                  I'm confused here too. Can u explain some more?
                  • Herrmann
                    • Jan 2006
                    • 792
                    Just a shot on the dark:
                    i had something similar on another brand years ago: a solenoid of a feed unit touched a scratched insulation of a wire while activated, resulting in a short circuit of a 24v dc powerline. The box throws a laser error, cost me days to find that out. Maybe its something like this.
                    • z_ming
                      • Jul 2011
                      • 31
                      I had same issue before . It's definitely one of the color pcu
                      • patterson70
                        • May 2010
                        • 599
                        Excellent advice, thank you. Could you tell me where the solinoid was located?
                        • z_ming
                          • Jul 2011
                          • 31
                          When i was encountered this issuse ,i brought 4 pcu to the scene ( these 4 pcu all work well in anther MPC 2500). when i replaced the yellow one ,suddenly it worked out.
                          • jonezy999
                            just one copy??
                            • Feb 2010
                            • 952
                            That would be the simplest way to get the ball rolling.
