Ricoh MP C4500 Issues scanning to network drive
  • dmartin
    • Jul 2025
    [Misc] Ricoh MP C4500 Issues scanning to network drive
    Hi there,
    I have a Ricoh MP C4500 that we have setup to print to a network drive. We do have Active directory, but we created a user just for the scanner so that the employees can just go and scan what they need and it will be in a generic folder for them to grab (we only have 13 people in the office) So most of them have no problems at all doing this, but I have 2-3 that say it takes anywhere from 15 minutes to 4 hours for their scans to show up in the network folder. Does anyone have any ideas what this could be or what we can try to fix this. I have just physically shut down the printer for like 2-3 minutes and then started it again and SOMETIMES that helps, but I figure there has to be something else that would cause this. Any help would be greatly appreciated!
    Thanks!
  • Jomama46
    • 2900
    Re: Ricoh MP C4500 Issues scanning to network drive
    Perhaps they are setting the resolution too high, scanning color will also make a huge file. other than that, look at the nw switch or router.
    sigpic
    A+; Network +; PDI+
    • dmartin
      They dont change any settings when they send compared to when the one that it works for does it.
      What do you mean by nw switch or router??
      • Jomama46
        • 2900
        network switch or router may cause slowdowns
        sigpic
        A+; Network +; PDI+
        • teebee1234
          • Jul 2008
          • 1670
          Check the display after the scanning is finished. Does the memory percentage go back to 100% and the data light go off fairly quickly? Once that happens then that scan has left the device and is now in the hands of the network. If it takes a long time to get to the folder, then your IT person will have to determine the problem. One way to troubleshoot is to set up a shared folder directly on the PC of one of the users that is having this problem and set a path to it in the address book. If the scanning is normal in that situation then that is one more confirmation that the issue is with the network somewhere.
