ricoh printer c410?
  • loverkoko
    • 35
    ricoh printer c410?
    i have yellow stroke around the words any one help me?
  • teebee1234
    • Jul 2008
    • 1670
    Re: ricoh printer c410?
    • Can you post a sample or be a little more precise?
    • Are you saying there is a yellow 'halo' or tinge completely surrounding the words or does it appear to be a yellow shift of the actual letters?
    • What driver are you using and what application(s) is producing this effect.
    • If it's a shift of the letter then I would say that your registration is off (assuming it's printing in process black).
    • If it is a "halo" then I would suspect you need to check the application or better yet check the driver and make some changes in the print quality settings ('print all text as black', 'raster' or 'vector',...).
    • You mostly see these kind of issues print PS files
    • It wouldn't hurt to make make that the firmware is up to date.
