ricoh 3228c magenta calibration
Re: ricoh 3228c magenta calibration
See attached document.Attached Files -
Greeny
Hi there!
Iagree with Greeny, take aclose look at the transferbeltunit. It is important to clean the rollers properly, the belt (if not too old) inside with white spirit and change the cleaningblade + BIASroller. In allmost cases the machine is running again without problems.
Greetings...Comment
Look at the drive unit in the rear of the machine. It is possible that the large white pinion has some expansion and cause the deviation or it may be that in a visit that pinion is turned upside down and align the machine while all colors except magenta. If it solved the problem once you must make a tight fit line.
Greetings and good luck.Comment
Seen something like this once. Had followed up on another tech for this issue. One of the drum drive gears was installed flipped front to back and caused an issue that looked much like yours. This occurred after the tech in question had changed dev clutches (of course this wasn't mentioned until I was about ready to hang myself) and messed up reassembly. The issue was not obvious without actually taking the drive apart again.Comment
Yep. Magenta would be the only color out of adjustment. Color registration in user tools as well as line position adjustments in sp modes would not correct the problem. Tried replacing and adjusting all of the usual stuff before replacing BICU NVRAM. Sounds crazy, I know, but that was the fix.Do what you can, with what you have, where you are. ~Theodore RooseveltComment
