I have a Lanier 5705 that is giving a SC510 error code. Book says (paper feed motor lock) so I replaced the motor. But, I still get the error code. Paper bunches up right at upper registration roller. I am going to replace the upper registration roller next. Just wondering what everyone else would do in this case.
Ricoh 1105 SC510
Will the motor run in I/O checks? which tray or trays 1,2,3 or 4,5,6?? how many clicks on this unit? over 2 or 3 mil pul the feed statiions for inspection and bad gears, and pull the reg section and check the mylar guides.Mystic Crystal RevelationsComment
Re: Ricoh 1105 SC510
Try replacing door switches. In particular the one by itself. I have had motor lock codes and this usually solved the problemComment
