Lan fax on MP2550 for Windows 7
  • copyaction
    • Oct 2007
    • 991
    I have a customer with an MP2550 with print scan anf fax that is trying to set up Lan faxing. Is there a setup procedure listed somewhere, I could not find it on the downloads page of the Ricoh website
    Thanks.
  • sandmanmac
    • 3981
    Re: Lan fax on MP2550 for Windows 7
    Download the LanFax driver, and install using the same IP address as the printer. To use it, just print as usual, only select LanFax as the printer. There are settings like cover pages, and address books that can be setup for each individual user (if it's installed locally on each PC)
    Here: http://support.ricoh.com/bb/html/dr_....htm#Microsoft Windows 7
    • nmfaxman
      • 1702
      X2. Doesn't work well n a server because of the address book and cover sheet functions.
      Available for both 32 & 64 bit Win 7.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        I havn't seen any W7 lanfax drivers from Ricoh yet, and I'm on TSRC daily. Have you guy's?
        Mystic Crystal Revelations
        • teebee1234
          • Jul 2008
          • 1670
          Not sure where you have been looking, but you will find them on the ricoh.com site.
          mp2550 win7 lanfax drivers here
          • copyaction
            • Oct 2007
            • 991
            Thanks guys
