I have a customer with an MP2550 with print scan anf fax that is trying to set up Lan faxing. Is there a setup procedure listed somewhere, I could not find it on the downloads page of the Ricoh website
Thanks.
Download the LanFax driver, and install using the same IP address as the printer. To use it, just print as usual, only select LanFax as the printer. There are settings like cover pages, and address books that can be setup for each individual user (if it's installed locally on each PC)
