sc440
  • Llama God
    • Mar 2009
    • 1353
    Re: sc440
    Obviously you're stupid as you can't troubleshoot a main motor fault, and ridiculous comment such as "main motorrrrrrrrrrrrrrr" will get you nowhere fast.
    I'd wish you good luck, however I'd be lying if I said that.
    • lupi
      • Aug 2011
      • 102
      Re: sc440
      [QUOTE=vargue;287043]i worked in machine about 5 years yesterday it pop up sc440 can some help how can i fix main motor notice: it's appeared immeditly when i open machine. i ecountred this threat in machine 2045 but in feed motor but it was rolling but his torque is very weak.need help.thanks[/QUOTMain motor lockThe PLL lock signal remained HIGH while the main motor was off, and when the motor was turned on, the signal remained LOW for 2 sec.>Physical overload on drive mechanism >Main motor drive board PCB defective
      • ZeusGT
        • 271
        Re: sc440
        Can't say in the 18 years that I have been fixing copiers, I've ever seen a main motor just go bad. I believe I would be measuring voltages at the motor and power supply. If I'm not mistaken, didn't the interlock switches go bad on this model causing laser failure faults and cause odd electrical gremlins. Just sayin, I wouldn't automatically suspect the main motor just yet.
        CompTia A+ Certified
        CompTia Net+ Certified
        CompTia Server+ Certified
        CompTia Project+ Certified
        OP Scanshare Certified
        • enygma
          • Aug 2009
          • 17
          #19
          Re: sc440
          There is a cold solder on the main motor coil. There are 3 contact of coil that is soldered to the pcb. One of them is 100% sure that is not connected to the pcb.
          • cleardata
            • Jul 2011
            • 137
            #20
            Re: sc440
            x2 to this...
