I am looking for some assistance in fixing an error I receive whilst trying to scan using an Infotec ISC824.
I am using the following from a Windows XP computer:
DesktopBinder v5 Lite
TWAIN v3
(both downloaded from Ricoh website)
In DesktopBinder TWAIN is showing as Type 1232 Scanner 3.7900 (32-32)
When trying to scan, it shows : Searching then 12320 : cannot find the scanner
Check if the scanner main power is on
then
Opening of the [Browse for TWAIN Driver] dialog box has failed (301-231)
I have read that this may be due to firewall issues but I have disabled Kapersky and still receive the same error.
The Infotec is not connected through a router but direct through the parallel cable.
Finally, unsure if there is a connection however, the PC has an yellow exclamation showing that the SM Bus Controller is not working in Device Manager.
I will be picking problem back up in the next few weeks so any assistance/ tips/ guidance would be grateful for my return.
Many thanks in advance.
David.
TWAIN v3
then
David.
