Java VM Card Update Procedure
  • Llama God
    • Mar 2009
    • 1353
    Hi,
    My latest dumb-ass question regarding Java VM Cards is this: does anybody know where to find the update procedure? I've hunted high and low on Tessa with no luck.
    Thanks,
    Chris
    p.s. I already have the manual, Paul!
  • Eric1968
    • 2458
    Re: Java VM Card Update Procedure
    Wel it isn't a dumb-ass question. The training manual says the VM Card Update Tool can be downloaded from Tessa, but I also can't find it. If I find it I will let you know.
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 417
      If you search for Firmware on Tessa, when you've selected "Multifunctional Products" then selected the specific model "MPC7501" for instance, there's a link to "Java VM Card Update" listed with all the other firmware (or frimwares if you prefer ).
      Is that what you're after? Because I've yet to have to use this myself for anything.
      • Llama God
        • Mar 2009
        • 1353
        I've got the firmware, however I'm sure that there's a specific procedure to install it rather than doing it like the other firmware updates.
        There's no tool listed for the MP5001.
        • fbkhan3
          • May 2012
          • 421
          Originally posted by Llama God
          Hi,
          Thanks,
          Chris
          I'm Not sure if you lookin for this Sir,i found it on Tessa,Update procedure for VM option.
          if you also need Java update firmware it's there on tessa you may check that out.
          • Llama God
            • Mar 2009
            • 1353
            Perfect, that's just what I was looking for, thank you!
            • fbkhan3
              • May 2012
              • 421
              you welcome sir,
