c3500 DF hinges
  • tinfox
    • 317
    c3500 DF hinges
    I have a customer whose DF is a bit loose and is falling on their hands while copying checks. Can these be tightened or do they have to be replaced?
  • Gift
    • Mar 2011
    • 2422
    Re: c3500 DF hinges
    There's a modification available that tightens the hinge-spring - very easy to install and not pricey. Unfortunately I don't have access to my technical database right now.
    • tinfox
      • 317
      Re: c3500 DF hinges
      Okay that's good to know. Let me know if you can find the part number. Btw is this something that is common on this doc feeder?
      • Gift
        • Mar 2011
        • 2422
        Re: c3500 DF hinges
        Yes - I've also seen broken hinges on machines with heavy usage. I'll check it next week in case noone else can look into the DF3010 bulletins in in the meantime.
        • Eric1968
          • 2459
          Re: c3500 DF hinges
          Just went through the DF3010 RTB. It seems there's sometimes not enough grease applied to the cam of the left hinge. A spacer has to placed just below the big springs of the LEFT hinge (Part No. : B223 9450). If there's too little grease on on the hinge, you should apply it on both sidesof the spacer. The grease should be : Silicone Grease G-501 (Part no. : 5203 9502).
