Hi,
I'm having some trouble with a MPC 3501 where the network "card" part in not working properly. There is only light in one LED (yellow) on the network connector/port/receptacle (what's the right word to use?), and it can not obtain an IP adresse from the switch when it's in DHCP mode. Every thing else seems to work fine. Can get all reports and what not from the machine, including network data sheets/reports.
I have tried new firmware, formattet the HDD, changed the printer controller board and the BICU with no luck.
I've browsed through the service manual and can not find out what the flashing LEDs on the BICU board mean. I've got two green and one red. There is also a LED flashing red on the IOB.
It's only printed 7000 pages or so.
Any tips?
Any tips?
