try the front and side doors switches
SC 322 | [SC322 laser synchronization detector error] - make sure CN344 on IPU PCB pluged in correctly (bad connection) |
SC 322 | [SC322] - make sure CN344 on IPU PCB pluged in correctly (bad connection) |
SC 322 | Laser synchronization detector error - Make sure CN344 on IPU PCB pluged in correctly (bad connection) |
SC 322 | Laser synchronization detector error - Replace laser diode PCB |
SC 322 | Laser synchronization detector error - Replace laser sync detect PCB |
SC 322 | Laser synchronization detector error - Replaced front door safety switch |
SC 322 | Replaced front door safety switch |
SC 322 laser synchronization detector error | [SC322 laser synchronization detector error] - make sure CN344 on IPU PCB pluged in correctly (bad connection) |
