Re: MP 7500SP supervisor login change
The reset worked, I'm now using it as a lever for a pay rise. Fat fucking chance of that!
Should u have an access to other machine ( the same model) just copy NVRAM and overwrite the one withn the passwords set up. It should workLeave a comment:
There is an SP (SP 5-846-46) that can be run from 'Factory SP' that will reinitialize the UCS settings back to defaults. I have tested this on GW and GW+ machines and it does work. Authentication settings will still be active but the passwords will be null. IIRC from my testing it tosses the address book too, similar to SP 5-846-50.Leave a comment:
Like I said, I have tested this by setting both admin and supervisor passwords and testing that access is restricted, then running the SP I indicated (which is only available from factory SP mode) clears both back to default. This SP will not be found in the service manual and is not the same reset as the UCS that is listed in the SM.SP 5-801-11 will not reset the admin or supervisor passwords.Leave a comment:
It is already on this forum. I'm not interested in splashing about instructions for accessing 'Factory Mode', it is actually only supposed to be used by regional technical specialists / support personnel. Do a search for it and go through some threads, you will find it.Leave a comment:
In the Security Settings manual...................."Be sure not to forget the supervisor login user name and login password. Ifyou do forget them, a service representative will to have to return the machineto its default state. This will result in all data in the machine being lostand the service call may not be free of charge."That would be a Ram reset??Leave a comment:
I've read that you can change supervisor if you go into Factory mode, haven't had a look myself. (Not SP mode), otherwise you're probably gonna have to replace NVRAM. let us know if you need help getting into 'factory mode'Leave a comment:
Hi, Can anyone tell me How can I reset supervisor login and pasword because someone change the default login for supervisor and I can t log on into menu.Thanks,Tags: None
