Ricoh Aficio 700/ Savin 2070dp - SC 510
  • ignacio.cortez
    • Jul 2010
    • 176
    [Error Code] Ricoh Aficio 700/ Savin 2070dp - SC 510
    Hi,My brother's church in Texas has a Savin 2070dp, with a SC 510, what I've been able to find is that is the LCT Motor, however the jams and code happens when making copies from ANY of the trays, except the Manual/Bypass tray, So I'm thinking it could be a transport motor. I don't have a Service Manual / Parts Manual And need to know if any of the motors on the other trays are the same as the Motor in question, Any one can send me or point me to where I can download the manual free so I can send it to him and give him some instructions on what to do?PS. this copier is out of service contract, a technician came to "check it" a couple of days before the contract ended, and 3 days later it started failing and Jamming out of the transport area, I have a feeling that the tech might have replaced a motor either on his own or by request so that the church would buy a new copier from them (the companies I've worked for do not do that practice) but I have heard of others that do.Any help would be welcome, this church does not have money to buy another copier
  • Bantams
    • Jun 2012
    • 603
    Re: Ricoh Aficio 700/ Savin 2070dp - SC 510
    SC510: LCT tray malfunction (optional LCT)
    -Definition- [C]
    1) The LCT lift sensor does not activate for more than 18 seconds after the
    LCT motor starts to lift the bottom plate.
    2) The LCT down sensor does not activate for more than 18 seconds after the
    LCT motor starts to lower the bottom plate.
    3) The LCT lift sensor is already activated when the LCT cover is closed after
    paper is loaded.
    4) During paper lifting, the LCT lift sensor does not activate for more than 2.5
    seconds after the paper end sensor turned on.
    - Possible causes -
    LCT lift motor defective
    Pick-up solenoid defective
    Poor motor connector connection
    Poor pick-up solenoid connector connection
    Paper end sensor defective
    LCT lift sensor defective
    LCT lower limit sensor defective
    • kyrenecopy
      • Apr 2012
      • 205
      A292/A293 S C 5 10 paper feed motor locks lower front door safety switch bracket or actuator
      A292/A293 S C 5 10 paper feed motor locks lower front door safety switch defective
      A292/A293 S C 5 10 paper feed motor locks paper feed motor
      Testing 1-2-3, testing, testing. Is this thing on?
      • ignacio.cortez
        • Jul 2010
        • 176
        Originally posted by Bantams
        SC510: LCT tray malfunction (optional LCT)-Definition- [C]1) The LCT lift sensor does not activate for more than 18 seconds after theLCT motor starts to lift the bottom plate.2) The LCT down sensor does not activate for more than 18 seconds after theLCT motor starts to lower the bottom plate.3) The LCT lift sensor is already activated when the LCT cover is closed afterpaper is loaded.4) During paper lifting, the LCT lift sensor does not activate for more than 2.5seconds after the paper end sensor turned on.- Possible causes -LCT lift motor defectivePick-up solenoid defectivePoor motor connector connectionPoor pick-up solenoid connector connectionPaper end sensor defectiveLCT lift sensor defectiveLCT lower limit sensor defective
        Well, Thanks for the Info, Though I had already Googled it, But I think my questions were something like:Can anyone tell me where I can download it for free?And Is the Motor the same as other motors on the MFP? http://www.copytechnet.com/forums/im...ies/tongue.png
        • tcs04
          FORMER Techie
          • 1183
          x2... Check the lower right door switch actuator isn't deformed.
          • JustManuals
            • Jan 2006
            • 9838
            http://www.justmanuals.com
            Paul@justmanuals.com
            • ignacio.cortez
              • Jul 2010
              • 176
              Originally posted by manuals4you
              This Parts & Service Manual can now be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.comPaul@justmanuals.com
              Thanks Dude, BTW Nice Profile PIC :-)
