MP C2550 (SC 565)
  • sharpmind
    • Sep 2009
    • 478
    [Error Code] MP C2550 (SC 565)
    This error code occurs intermittently. I already replaced the two pressure roller thermistors but still error occurs. The machine has a counter around 150K. Any ideas why it is happening? Is the thermostat bad?If yes, why the machine is getting ready once I cycle the power off and on? I still have not checked the fusing connector, but how can it be defective since the fusing unit has not been removed frequently. I am confused with this kind of error.
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: MP C2550 (SC 565)
    have you pm'd the fuser unit (pm 150k) if not just EITHER replace the unit as a whole/rebuild or its possible the psu but go for the fuser first. press lamps working? sp1106
    Incontinentia Buttocks
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • sharpmind
        • Sep 2009
        • 478
        Problem solved!I rechecked the fusing unit and I found the pressure roller thermostat busted. I just knocked it on the floor and it worked again.
        • TonerMunkeh
          Professional Moron
          • 3865
          The SC codes on the Diana and the Apollons / Athenas can be a total arse. Turns out they can run with a blown thermostat and only code out occasionally.
          Hit it.
          • FMC
            • Aug 2008
            • 88
            Tut tut, don't let a certain person know you did that, he'll start giving you shit for it
