Key Operator Code
  • rdinapoli
    Key Operator Code
    A charity group I do free work for recently purchased a used Ricoh Aficio 2045eSP. The problem is the "Key Operator Code" is programed and I am unable to add it to the network. The vendor who sold it to them couldn't or wouldn't reset it for them. Is there an easy way to get around this, or is there a default key code that always works, or do they need to call in a tech to do the reset?
  • Ollie1981
    Toner Monkey
    • Mar 2008
    • 417
    PM sent!
    • nmfaxman
      • 1702
      A tech needs to go into service mode to reset the key op code.
      Have them reset it and give you an estimate to put the machine under contract.
      They will make it run and maybe show you simple repairs.
      Giving you the code could cost more if you set something wrong.
      • rdinapoli
        Thanks, but problem is solved.
        • NothingCtrl
          Can't anyone help me, i have same problem, when i power on, it's require Key Operator Code to start, i don't set any code...
          My printer is Ricoh Aficio 1045
          How i can fix that problem?
          (sorry my bad english.)
          • NothingCtrl
            oh, sorry problem is solve.
            • alsi5
              • Sep 2010
              • 51
              I have same problem (key operator code) in Ricoh 2022. I need to create a new user account but now it is impossible ;/ I don't have any contact to company who's sold this copier. Please help ASAP.
              • Jomama46
                • 2900
                Jeepers, a guy can make a chunk of change just resetting the KO code.
                sigpic
                A+; Network +; PDI+
