Savin 4065 or Printer/Scanner Unit Type 2075 SD card
  • satcom12
    • Jun 2025
    I am Looking for a Printer/Scanner Type 2075 SD card or if it is possible to download a new file on the card to replace the corrupt file on the card?
    Can anyone direct me where to get one without buying the whole scanner/printer kit as only the card is bad?
  • sandmanmac
    • 3979
    Re: Savin 4065 or Printer/Scanner Unit Type 2075 SD card
    You can't repair the file system on the card. I would try Googling the P/N on the card and you'll likely find a source on Ebay or similar; Otherwise, if you have access to Ricoh ordering, the cards have been pretty reasonably priced (the couple of times I've needed them).
    Just wondering what problem are you having? How do you know the SD card is actually the problem?
    • satcom12
      I replaced the network card and it was not that.
      I had a tech diagnose the machine and he said it was either the sd card or the mainboard.
      So hoping it is the sd card and if cheap enough just try one to see if it works.
      • sandmanmac
        • 3979
        Originally posted by satcom12
        I replaced the network card and it was not that.I had a tech diagnose the machine and he said it was either the sd card or the mainboard.So hoping it is the sd card and if cheap enough just try one to see if it works.
        I'll try to ask more clearly. What is the exact issue you're having? What led to this problem? Was the machine working properly then suddenly stopped printing? Any error messages? As the print/scan functions still available on the op. panel?Not saying that it can't happen and I'm sue it does, but I personally have not had an SD card just fail out of the blue
        • Llama God
          • Mar 2009
          • 1353
          I agree, I have never had one of these go down, nor have I had a controller fail.
          • satcom12
            Machine was working fine and when I went to print to it it gave "printer not found"
            The scanner/printer features disappeared off of the user/tools panel. When I go into interface it has network and parellel interfaces. When I click on network and go to the screen with IP, DNS, Gateway,,, they are all blank. When I go to set the GW the screen freezes and after about 1 min it goes back to the same screen without letting me set the GW.
            • sandmanmac
              • 3979
              Hmm...it seems you may actually be looking at a corrupted SD card. But first I'd try removing the Memory Dimms, clean contacts and re-seat
              • satcom12
                Already removed the mem and reseated. Also removed and put back in sd card, network card, ...
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Firmware would be the next step I think.
                  Hit it.
