SR3000 misfeed no paper
  • FRP
    • Jun 2025
    have a mpc2500 with SR3000, paper jam R1-R3, paper stops in bright. this is not happend every time.
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    Re: SR3000 misfeed no paper
    Any more info?
    • sharpmind
      • Sep 2009
      • 478
      Check and clean the bushings in the entrance roller. If the machine immediately shows paper jam in R1 and R3 during the startup, most likely the shift tray motor is not functioning properly.
      • FRP
        After new start op, the maskin copys 20-40 copys topp trey or skift trey.widt a stop the isnt visual damages on the paper.and the maskin stoping every 3-5 copys.I have tryed new bright. no luck.
