ricoh aficio 2232c
  • RWAFA
    • Aug 2011
    • 68
    ricoh aficio 2232c
    hi guy,i have my ricoh aficio 2232c color copier whiuch is not copying,if i press start button the machine does not copy but gives a msg of copping but does not produce the copy,does any 1 knows wht it could be? plz help im stranded.,
  • JustManuals
    • Jan 2006
    • 9838
    Re: ricoh aficio 2232c
    Paul@justmanuals.com
    • rthonpm
      • Aug 2007
      • 2849
      On each function of the machine, press the yellow Clear button and the red Stop button at the same time. When you reach the function that's locked waiting for a prompt you'll hear the fans and lasers start up again. Rebooting the machine will do the same thing, but that's usually a good starting point.
      • cva
        • Jul 2012
        • 23
        bro try change fusing unit,, more probly thermisters problem other else firmware or hdd
        • George J
          • 107
          +1 for the fuser
          • Eric1968
            • 2458
            If the Fusing Unit is the problem the machine would throw SC-codes.
            • cva
              • Jul 2012
              • 23
              im had face these case but not have any error code shown. finally im chang the fusing unit. i got solve the problem. later i check the fusing unit>>>> 1 thermal fuse its out of order.
