Ricoh 2045 stapling problem
  • slim
    • Jan 2008
    • 30
    Have a SR880 finisher that does not staple in the correct postion. At the default setting in SM, the staple is half on the page. Max the value out and it is better, but not where it should be. Corner stapling is fine, to me.... I have replaced the stepping motor that moves the stapler back and forth and also the swivel motor. Tried a finisher control board also with no luck. Any thoughts.
  • Ricoh-ono
    • 338
    Have you checked that the jogger fences are moving in close enough to the paper?
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
    • kyoceran
      • 100
      stapler
      it is possible the stapler home position sensor is slightly out of position, its worth a quick check, does the stapler make a grinding noise ?
      Good luck
      • slim
        • Jan 2008
        • 30
        The paper is aligned correctly by the jogger fences. Tried swapping the home position sensor with another with the same results.
        • slim
          • Jan 2008
          • 30
          Yes, the sensor is in the correct spot.
