lanier ld015spf scanner set up problem
  • irokkas
    • Oct 2012
    • 18
    i can't set up scanner.message ''no response from scanner'' still comes up.
  • luke001
    • Dec 2011
    • 46
    Re: lanier ld015spf scanner set up problem
    Settings in Twain driver custom settings and enter the IP address.
    • sandmanmac
      • 3963
      This is a "Network Twain" driver, so the machine MUST be connected via tcp/ip for it to function. I suspect you have it connected to the USB port (??)
      ....EDIT: after re-reading your post,you have installed the "network twain" driver right?
      • irokkas
        • Oct 2012
        • 18
        thank you very much for your help.
        customer's pc had some sort of problem.with mine's works great.
