RICOH MP3010
  • msmy
    • May 2010
    • 123
    RICOH MP3010
    Hi,
    Just to ask about printer and fax on MP3010/MP2510. I just bought 7 used machine. I have no experience on this model before. I want install printer function on the copier (where comes without printer and fax cards). I saw there are three slot for SD card (For Fax & Printer). So I swap these card from other copier (with printer and fax function), but the new copier still don't have these function. Any other setting need to do?
    cheers,
  • Eric1968
    • 2458
    Re: RICOH MP3010
    You can't use a Printer/Scanner SD-Card from another machine. These cards can only be used in one machine. You also can't copy the contents from one SD-Card to another.
    The Fax Unit is not on a SD-Card. The Fax Unit comes with an FCU-Board, a little speaker, LINE/TEL-connections and buttons for the Control Panel. The FCU-Board has to be attached to the Controller Board.
    • msmy
      • May 2010
      • 123
      Re: RICOH MP3010
      this type of machine come with all in one (the controller board have all, including fax but without card-one I have card for fax (written on card)), not like AF2027 or AF3030, they have to add printer card or fax.
      • sandmanmac
        • 3981
        Re: RICOH MP3010
        Eric1968 is correct. The fax feature does not require an SD card on this model -only additional circuitry, and control panel buttons
        The print/scan installation requires: SD card, 256Mb Dimm, HDD, buttons (below), and a couple of Service procedures after installation.
        And as he also said, the SD must be specifically for the MP2510/3010 models
        • JustManuals
          • Jan 2006
          • 9838
          Re: RICOH MP3010
          Paul@justmanuals.com
          • msmy
            • May 2010
            • 123
            Re: RICOH MP3010
            Dear Sandmanmac,
            Today I received the sdcard type 3010 for printer + scanner. I add ram 128MB x 2 = 256MB. However, when I switched on, there are no printer option/cannot use printer opt. Do I need to do some other setting? and how? pleaseeee...
            • sandmanmac
              • 3981
              Re: RICOH MP3010
              Originally posted by msmy
              Dear Sandmanmac,
              No need to address me personally...
              There are several much more enlightened people here than me, which I'll now call on for input, because I doubt that 2 x 128Mb Dimms will work, and they're not "universal" either.
              1 slot on the controller should have already had a 128Mb Dimm in it, which is for basic operation, and standard on the machine I believe (??). The "proper print/scan" contains 1 x 256Mb for the other slot (as mentioned above).
              You also didn't mention a hard drive??? While I don't think that prevents the features from showing up, they won't function without it.
              So, it seems, NOT only are you trying to take shortcuts with the advice we're giving you, you have no reference manual which is a MUST for attempting to do this type of thing. and 'YES' there will be several other things that need to be done once you have the proper parts installed, but they don't prevent the features from showing up if you've done it right in the first place. (just my 2 cents)
