MPC2050
  • GeorgeBest
    • Jul 2009
    • 526
    MPC2050
    HI,
    Had an SC563 on this machine.
    I replaced both pressure thermistor, middle and front.
    Did some testprints, it looked allright to me.
    Now, customer called for an SC565 error (?)
    Need I replace the whole unit or . . ?
    anyone . . Thanks in advance
  • coolbeer
    • Jul 2011
    • 100
    Re: MPC2050
    According to manual could also be pressure roller thermostat or PSU, good luck !
    • fbkhan3
      • May 2012
      • 421
      Re: MPC2050
      Edition to as cool bear said,make sure you had Pressure roller thermistors(Middle and front) with correct part number in the box,or it'll cause overheating,blowing thermostat and PSU!
      • stig
        OVERWORKED..UNDERPAID
        • 52
        Re: MPC2050
        Yes I agree with COOLBEER, I had this happen to me sc563 so I replaced thermisters then got a call for sc565 not long after leaving the premises. Went back with a presure roller thermostat and its been ok since. This happened to me twice on 2 different mpc2050s so when it happened again i replaced thermistors and pressure roller thermostat
        • Masterchief
          • Apr 2011
          • 280
          Re: MPC2050
          Replace all thermistors and pr thermostat, and make sure the contact is correct, if problem persists try the female connector inside the machine where the fuser male connector meets, I have seen them break when customers remove to clear a jam and slam them back in causing them to break....
          If it is broken, it will take app 2 hours to replace as a heads up
          sigpic
          • Polarbear
            • Feb 2012
            • 1070
            Re: MPC2050
            Chaps also make sure that all the lamps in the fuser are ok. Sometimes a failed fusing lamp (in a multi-lamp fuser) can cause the wrong sc codes.
            Press the GREEN button!!
            • mikadonovan
              • May 2008
              • 2931
              Re: MPC2050
              Happened to me too. You can check continuity without removing the pressure roller, but it has to come out to replace the thermostat.
              NEVER ASSUME ANYTHING
