Hi all,
this code happens first thing in the morning, switch on/off and m/c runs to the end of the day without problem. It logs also SC-499.
I checked every roller,every bearing, at ITB unit,sensors are clean, i replaced also PTR area parts, of course i found an old thread with same symptoms, but without a fix.
Thanks in advance for any input...
