my client has a ricoh mp c4500 we found it not loading the black toner when we tried working on it instead gave us sc 536 error code what could be the problem and this possibly after cleaning the black pump
mp c 4500 not loading black toner
Tags: None
Re: mp c 4500 not loading black toner
You can try and clean out the toner pipe and the nozzle assy with the toner end sensor attached first, but it usually needs a new pump. common fault and probably answered many times on here in different threads. -
Oh and i have had a couple where the dev drive gear has worn right down giving same fault, this occured when units have not been changed at correct pm counts. just something easy to check first.Comment
Regarding SC536.
SC536 Third duct fan error
Problem: The machine does not detect the fan motor lock signal for 2 seconds after the third duct fan is turned on. - DID YOU DISCONNECT ANY HARNESSES when you were cleaning the pump?
Cause: Disconnected harness. Third duct motor overload. Defective third duct motor. Defective IOB
Resolution:
1. Check or replace the harness
2. Replace the third duct fan
3. Replace the IOB
Regarding BK toner not recognized (let's assume you have cleaned everything good - pump + hoses etc.):
1. Make sure you are using a GENUINE toner not generic junk - creates more issues than gives you an advantage in price.
2. Make sure toner bottle chip exists and not damaged
3. Make sure that toner Type you are trying to use is a correct one - it MUST be MP C4500.
4. If you cleaned the pump but it still doesn't recognize it - REPLACE a pump (part# B223 3211)
That is it. Good luck!Comment
hi guys thanks for the info will change the horse and pumpsComment
Paul@justmanuals.comComment
