Ricoh 240w led head is it same as MP w2400 led head?
  • copierpro
    • Apr 2007
    • 270
    I don;t have the parts manual for the w2400 but is the led head for the 240w B125 1859 interchangeable with the mp w2400 led head?
  • jdzr
    • 125
    Re: Ricoh 240w led head is it same as MP w2400 led head?
    Parts manual calls for the B286/LW324/2404WD/MPW2400 to use the same head part# B2861860. Major changes were made to the 2400w so I do not think you can adapt it to work. Good luck
    • copierpro
      • Apr 2007
      • 270
      What is the B286 1859 listed for w2400? Note the 240w uses B125 1859.
      • jdzr
        • 125
        My manual does not show that part number at all. It shows all of these machines use part# B2861860--- B286/LW324/2404WD/MPW2400
        I guess I could have an out dated manual but that is what I have.
        • copierpro
          • Apr 2007
          • 270
          OK, thanks. Removed the LED head and the three LEDS are B125 1997 part numbers on this B286 1860 LED head. I think the ground is different. The 240w manual shows one ground and this led has two braided ground cables.
          • jdzr
            • 125
            Thanks for getting back with the info --- I'll make a note of that one.
            • copierpro
              • Apr 2007
              • 270
              By any chance you know where I can get a CIS lamp for the CIS unit for the MP w2400/3600? I need one that has broken pin, furthermost right lamp.
              • jdzr
                • 125
                Sorry but I can not help you with that one. I can get you a new one from Ricoh but I do not know at what price. If it will help you I can send you a copy of the parts manual just give me an email address to send it to.
                • copierpro
                  • Apr 2007
                  • 270
                  thanks support@copiergeeks.biz
