Ricoh 1224c
  • ralph olivieri
    Ricoh 1224c
    Does anyone know how to reset fuser oil counter on the Ricoh 1224c?
  • Steve Perks
    • Mar 2008
    • 32
    SP7804-011
    Team Leader/Technical Specialist: CMYK Digital Solutions Ltd
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      I would try this first then do what steve told you to do" reset counter" 1-930 Fusing Oil Add
      1 Fusing oil add Forces the oil pump to supply silicone oil up from the oil
      tank to the tank in the oil supply unit. If the oil end
      sensor detects oil in the oil supply unit, this SP will not
      start the pump.
      sigpicWe can all Win, but at the end we all loose. Save the greyhound
