Ricoh MP161
  • GeorgeBest
    • Jul 2009
    • 526
    Ricoh MP161
    We have a Ricoh MP 161 multifunction printer that we want to get setup to scan to a folder on our Windows Server 2008 domain controller.
    It doesn't work !
    I've read that Ricoh
    don't really support scanning to a folder on a domain. (in the past?)
    Is this issue resolved by firmware upgrade or is this problem still there on an MP161
    anyone ?, Thanks in advance
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MP161
    The NIB firmware needs to be at least version 6.17 (B8925526G), or the equivalent for your language/country/etc, to work with Windows Server 2008 correctly (you can use a lower firmware version but some problems still remain). You will need to update the firmware first, if you are a Ricoh engineer you should have access to these files, if not you will need to hire a Ricoh trained engineer.
    • Eric1968
      • 2458
      Re: Ricoh MP161
      X2
